Laptimer, metadata and video
september last year I did a trackway, set my best lap, and then removed the videos to save place on my iPhone.
Yesterday, went on the same track, and now would like to export videos with metadata and PIP best lap of September (with a different car, I should mention)
I didn't re-import the best lap video of September in the first place, and could have video PIP with metadata (speed, rpm, ...), but after re-importing the video and setting it as the ref, I lost the metadata...any idea ???
thanks in advance....
Re: Laptimer, metadata and video
What do you mean by "lost metadata"? Are you missing the gauges overlaid to the video?
Yes, no gauges on the right, rpm, gear, PS: all infos from OBD
Infos on the right: speed, g force,... are présent
Either OBD overlays are disabled (check Lap List ‣ your lap ‣ Video / Export ‣ Overlay Configuration ‣ OBD (for iOS, this is on the second page), or your lap has no OBD data stored.
I see, so I have videos with OBD datas that are on, and if I go back to original because I want to change the ref lap / pip, then I cannot export with OBD datas...
pic 1: no metadata found
pic 2:with metadata but wrong pip
- IMG_0089.PNG (183.37 KiB) Viewed 1861 times
- IMG_0088.PNG (203.33 KiB) Viewed 1861 times
hadn't finished editing my post: on the pic below, I cannot choose OBD, that is the problem, once I returned to original
Running the Overlay should add OBD gauges with this settings.
