syncing multiple gopro videos
arsprod
Post by arsprod » Sat Aug 19, 2017 5:05 pm
Since gopro breaks races into multiple videos (usually 2) is it better to combine these first before overlaying or overlay them separately and then combining? I'm seeing issues with both - when I combine into one video the timing seems to drift; when doing separately it's a pain to relink the separate videos. Thanks!
Aaron
Re: syncing multiple gopro videos
Post by Harry » Sun Aug 20, 2017 8:21 am
Usually concatenating the segments front up is the way to go. GoPros cut longer videos into 4GB segments. There should be no frame be lost, so you should not see a drift from video 1 to video 2. In case it is a general drift, please adjust the sync point.
arsprod
Post by arsprod » Sun Aug 20, 2017 1:17 pm
Any issues with changing resolution when combining video pieces?
Post by Harry » Sun Aug 20, 2017 1:23 pm
No, as long as combined timestamps are preserved and you are using a supported format, you can down sample / reduce resolution or even change frame rate using some video editor.
lzzl551
Post by lzzl551 » Tue Nov 21, 2017 4:04 am
Harry wrote:Hi,not 4G,is 12min segment,Video recording to 12 minutes will automatically generate new files, and so on,Video is segmented and file size does not matter
Cadillac 2016 ATSL 8AT in China 279hp/400nm
Go-Karting Praga Rotax Max Senior 28hp
Laptimer Grand Prix EDITION
iPhone6 64G IOS latest version and Samsung S7 Android7.0
TONWON BTLE OBD2
Gopro Hero4 session
