OBDII Gadgets on Overlay
TemeCal
Post by TemeCal »
Hi all-
Long time (very happy) user of HLT. I use an OBDII bluetooth dongle, to get additional data. When I overlay the video with the OBDII data, the coolant is a simple needle and RPMs just have tick marks.
Is there any way to get the actual coolant temp NUMBER, instead of seeing the needle? What about RPMs? Can numbers be placed in the tick marks?
Re: OBDII Gadgets on Overlay
I don't use the extended gadget because it doesn't have information I need, but I certainly get numbers for RPM
TemeCal
Post by TemeCal »
gplracerx wrote:I don't use the extended gadget because it doesn't have information I need, but I certainly get numbers for RPM
Oops…you're right - thanks! Mine does show the RPM numbers. Not sure what I was thinking :shock:
It's the coolant I'm after right now. Does anyone know if I can get the coolant numbers, instead of a needle gauge?
In LapTimer GrandPrix, you can switch the OBD gadget to a double gauge including oil or coolant temperature (in this order - depending on availability). The switch is located in the second page of Overlay Configuration (swipe in iOS, scroll down in Android).
TemeCal
Post by TemeCal »
Harry wrote:In LapTimer GrandPrix, you can switch the OBD gadget to a double gauge including oil or coolant temperature (in this order - depending on availability). The switch is located in the second page of Overlay Configuration (swipe in iOS, scroll down in Android).
Thanks Harry! I do have the GrandPrix edition. I'll get back in, and look for this!
TemeCal
Post by TemeCal »
Harry-
My second page shows "OBD II Gadget", but there is nothing next to it (no switches like the options above). Could this be, because I don't get oil temp data? I thought I remember you saying Porsche's oil PID is different, so we can't get them on our P-cars.
Thanks as always!
You should see None / Standard / Extended options. In case oil temp is not available, coolant is used.
TemeCal
Post by TemeCal »
Harry wrote:You should see None / Standard / Extended options. In case oil temp is not available, coolant is used.
Thanks Harry. I do see those options. Since they were below, I thought they applied to all options above. I figured "Extended" would give me the most info, so I didn't even try "Standard" Since coolant is what I want most, I'll give this a try.
Really appreciate your help. I sold HLT to another guy I met at the track on Sunday. Everyone is amazed with what it can do, and immediately download it while at the track. Thanks for the great product and wonderful support!
davidwarren
Post by davidwarren »
I just upgraded to the GP edition and have a Kiwi3 OBD dongle. Is there a way to get the coolant and oil temps overlaid with the actual temp? I couldn't tell from the above discussion.
Using LapTimer GP, there is an additional gauge available showing oil or coolant (depends on availability). It is very small however. But GP comes with a dedicated temperatures chart (Data Recording) in addition, allowing you to analyse this data in detail.
