Tried to add intro, now overlay linked to wrong video
I had a good overlay video. Wanted to pick it up a little early bf the start line, so hit overlay again with 20s intro rather than zero. Since then that lap links to a warmup lap, but the overlay is still the correct fast lap. Any ideas?
To re-overlay, you need to select the raw video for the lap first. I assume you have selected the wrong lap video recording or set th sync point not to the en of the names lap. Please check again. v16 will greatly improve this as it allows a simple Revert to the original video and sync point.
Re: Tried to add intro, now overlay linked to wrong video
Thanks for your fast response! The only original video left that i can find is the full lapping session video. How can i select that for re-overlay.
Please check the www.gps-laptimer.de/Video.html page first. Actually you need to navigate to your lap, press "Select" just below the video preview (in case you do not have it any more, press Edit and New Video), select the long session video. Now the critical step is to select the correct sync point which needs to be exactly this lap's end on the video. After having selected this sync point, overlay again.
