I was at Hockenheimring last Friday and this is the result
https://www.youtube.com/watch?v=qpqaUjYFk5g
The recorded video is not fluid at all (and it was the same before exporting with overlay). In addition I had a lot of issues (for example the exported video with overlay cannot be watched from Laptimer (but first copied to a computer).
Recorded videos are not fluid
Ferrarista
- 10 or more Posts ★
Re: Recorded videos are not fluid
This looks like the hardware has been overloaded... Video recording is done using an Android background process. In case resources like GPU, CPU, memory run short, a video like this can be the result. What's your hardware spec and do you have any resource intensive apps running in background.
Ferrarista
I have a Xiaomi Mi 9T Pro with Snapdragon 855 and Android 10 (including the latest GPU hardware acceleration). Honestly I'm quite surprised because I took some videos during the previous days who were much better than this...
If you watch this other video (taken some hours before at Hockenheimring) it's even worse.
https://www.youtube.com/watch?v=JKiNIbSMmdU
- PitrsRS
- 20 or more Posts ★★★
and if you record video only with camera app, not with laptimer? Is it ok?
2016 SEAT Leon CUPRA 290 ST
Ferrarista
- PitrsRS
and recorded ones with HLT without overlay are ok or bad?
It´s strange. I´m using HLT several years on different phones and everytime it was ok (except autofocus problems - solved with GoPro)
