No Engine Data after Update to Grand Prix
Posted: Mon Nov 04, 2019 9:26 am
I used Petrolhead for some times and it worked perfectly fine with my Android phone and OBD adaptor. I recently upgraded to Grand Prix and installed BLE TPMS then went for a track session. With all default settings, the record shows no OBD data at all, G force and tire information are fine.
In the engine panel, the rpm freeze at a value and no pedal info showing, like connected once and then lost (but there are some other info showing dynamically). I tried to change the OBD Tweaks-Adaptive Timing to "Aggressive", the rpm could show dynamically, but still no pedal info.
I also tried uninstalled the app and re-installed Petrolhead, it worked fine with engine data. But after upgraded to Grand Prix same OBD issue happened. I am not sure about other expert settings so did not change them.
Any idea?
Any idea?
