IOS 13.1 Potential issue with HLT ADMINISTRATION
Posted: Thu Sep 26, 2019 9:59 am
by llan981
I am using HLT v 23.0.07 and just pressed the Administration - Addons refresh button and the result is now I have a blank page. Right now ADD-On page is completely blank.
Now with, Prepare Race -Add New Track. When I use Prepare Race - Load Track - Select Track, and pick ALL -----NO Tracks are listed.
Re: IOS 13.1 Potential issue with HLT ADMINISTRATION
Posted: Thu Sep 26, 2019 10:10 am
This is most probably an issue with your Internet connection. I tested it for iOS13.1 a minute ago. LapTimer should keep the old track list in case a download (Refresh) fails, but obviously failed for your situation. Please Refresh again. It may be necessary to restart LapTimer or your smartphone to get caches cleared.
Posted: Thu Sep 26, 2019 10:21 am
by llan981
I am at 250MBPS up/down connection and tested it with Speedtest.net to be sure. Restarted HLT and did not work. Turned off IPhone restarted HLT and did not work. Now I turned off WIFI and just using cellular and it worked.
Posted: Thu Sep 26, 2019 10:35 am
Yes, so probably some cached and corrupted track list file on the WiFi path. These problems usually go away after some time (may be hours).
