Race>Classic + video in landscape on iOS
Posted: Thu Jul 11, 2019 1:17 am
When using Classic mode for recording, if the iPhone is in portrait orientation, the resulting video is sideways when later viewed. If using Classic mode for recording when the iPhone is in landscape orientation, the accelerometer is wrong but the resulting video is now otherwise correct. In further checking, Speedo mode seems to so this as well.
I ran into this because of what I would view as a UX issue: I mainly race low-speed autocross (ie SCCA Solo) which can involve rather tight courses. This, in turn, makes setting the GPS triggers in LapTimer rather tricky. Half the time they dont work right. After a couple years of stress and frustration I dont need from this, I started using Classic mode manually. That met my needs and removed a huge burden but raised the portrait vs landscape problem I described.
Any chance Classic could be updated to work in either orientation?
stephen
stephen
