Laps not recorded
Oswald
Laps not recorded
Post by Oswald » Sun Oct 21, 2018 6:32 pm
Laps are only recorded when I use video.
When not, nothing is recorded.
Re: Laps not recorded
Post by Harry » Mon Oct 22, 2018 3:43 pm
No, this will be some coincidence with a different problem. LapTimer production versions are regression tested without video before being released. It is possible detection doesn't trigger because of missing / bad GPS or missing track sets, or some other reason, but video is always an add-on.
NB: Recent LapTimer versions 22.1.x did not trigger laps for s/f lines going N/S or W/E plus some other rare scenarios. This issues will (hopefully) be fixed with 22.1.2. The current 22.1.1 should work a lot better than 22.1.0 already.
In case you are sure you used 22.1.1, please let me know which track set you used when running into the problem described.
Oswald
Post by Oswald » Tue Oct 23, 2018 8:00 pm
I am using v22.1.2.
It happend at Clastres and Abbeville. Only the laps where I use video are recorded.
Post by Harry » Wed Oct 24, 2018 4:21 pm
Just to clarify: you are using 22.1.2 now. As it has been released yesterday (Android), you will have used 21.1.0 or 21.1.1 for the date reported initially.
Oswald
Post by Oswald » Sat Nov 24, 2018 7:20 pm
Now it works perfect.
