I understand where are you heading, and yes I fully understand the fact about gears and they should go from the highest to the lowest, but this is not this case. I uploaded printcreen from the official SEAT (VW) technical brochure, as you can see even the manufacturer states that the fifth gear is higher than fourth and sixth.
That´s why I´m so confused about it.
Converting gear ratio to compatible value for Laptimer
- PitrsRS
Re: Converting gear ratio to compatible value for Laptimer
- DSG2.PNG (60.82 KiB) Viewed 685 times
2016 SEAT Leon CUPRA 290 ST
The table does not say for which gear which "Grupo reduccion" is used...
From the speeds given in the last row, I'm confident about these:
gear IV: 0,975 x 4,769 (grupo 1)
gear V: 1,030 x 3,444 (grupo 2)
gear VI: 0,825 x 3,444 (grupo 2)
In terms of continuity, I'm sure about gears II and III too:
gear II: 1,833 x 4,769 (grupo 1)
gear III: 1,300 x 4,769 (grupo 1)
What remains is gear I. My guess:
gear I: 2,933 x 4,769 (grupo 1)
