Track laps not splitting
Posted: Mon Jul 10, 2017 2:15 pm
by MrBlah
first time it happened at VIR full, yesterday I was at NCCAR and the same thing happened, it's not splitting laps. I'm using a racecapture pro mk2, and bluetooth to HLT, HLT also runs a gopro via wifi.
I also ran a wifi module this time and ran the racecapture app on another phone, it split the laps perfectly.
Here's some sample, right at the start you 1can see the map spinning, I've done a few trackdays with HLT before and did not have this problem with the racecapture, it started at the last trackday at vir.
I'm not sure what to look at in the data logs to see what is wrong
https://www.youtube.com/watch?v=jZ93W0g_P2U
Re: Track laps not splitting
Posted: Mon Jul 10, 2017 3:07 pm
by gplracerx
Try editing the Start/Finish and set the direction to 0.000. That will remove direction as a criterion. Then go to recalculate/Verify Lap. I don't think Harry as issued the update that improves direction calculation with RaceCapture devices yet. Also, what GPS rate are you using? A slower rate will, I think, improve direction calculation.
Posted: Mon Jul 10, 2017 4:11 pm
by MrBlah
how do I edit the start finish on a racetrack? this track runs both directions too, sometimes they flip at lunch
I use 25hz, works great with the racecapture app, and solostorm too I built the map for the track last week and both solostorm/racecapture picked it up and it worked.
I love how the racecapture lets you run wifi and bluetooth clients simultaneous. Solostorm even uses the gyro from the racecapture instead of the phone
Posted: Mon Jul 10, 2017 6:55 pm
by gplracerx
Touch the track set line in lap list. Touch the Start/Finish POI, scroll to the bottom and touch direction. Set all the numbers to zero and save. Don't reload the track set or you will have to do this again.
I don't have an Android device. That would make SoloStorm very expensive for me.
Posted: Wed Jul 12, 2017 1:04 am
by MrBlah
I cant find the "track set line" in the lap list
I can go into the session, click on the map and see the POI but it does not do anything when I touch it
I did verify laps and it's splitting in the wrong place, splits over on a turn that is near the straight where the start/finish actually is, but it did split the laps correctly once I modified "normal" to be 25 meters
it's like my gps is off or something, or major drift
Posted: Wed Jul 12, 2017 8:31 am
To find POIs (and modify them), select LapTimer ‣ Analysis ‣ Lap List. Scroll to the track the POI is associated to and find a row saying "User Defined Track Set" or "Certified Track Set". Press this row to get into "POI List" showing all POIs for this track. Touch one to modify it.
Posted: Wed Jul 12, 2017 12:46 pm
by MrBlah
thanks harry, I slowed all the logging down to 10hz will see if that improves things
