Page 2 of 6
Re: XGPS160 issues
Posted: Sun Oct 30, 2016 6:04 pm
by Veloscaraptor
Thanks Harry!
Re: XGPS160 issues
Posted: Tue Nov 01, 2016 1:54 pm
by Beast2012GT500
I just discovered I too have the 2.2.1 firmware which explains the behavior above. While the temporary fix you provide works Harry, will this interfere with the GoPoint BTI OBDII device I also use? I want to be able to use both the Skypro XGPS160 and the GoPoint BT1 at the same time.
Re: XGPS160 issues
Posted: Wed Nov 02, 2016 7:58 am
The workaround has no influence on a BT OBD connection, it is about GPS handling only.
Re: XGPS160 issues
Posted: Wed Nov 02, 2016 12:37 pm
by Beast2012GT500
Harry wrote:The workaround has no influence on a BT OBD connection, it is about GPS handling only.
Re: XGPS160 issues
Posted: Thu Nov 03, 2016 10:40 pm
by Dan Sweden
I upgraded to 20.2.2 during this weekend. I'm not sure exactly which version I had before but I think it was not the version before 20.2.2 but the version before that.
To my problem: After the update I could not get Vbox Sport to work properly (connected in iPhones Bluetooth but not in HLT) I'm not sure if it is related the XGP160 issue... It worked excellent before the update if HLT.
Another thing I'm having problem with is that I have at least one video that was recorded during an incomplete lap that now is not possible to view again (Error can not find video selected...) This particular video is from a crash so I really hope to be able to find it. I can see the preview in the list over LapTimer videos (Analysis->Video list). I could play the video before the update.
Re: XGPS160 issues
Posted: Fri Nov 04, 2016 8:45 am
Most probably, the update is the wrong place to look for a solution.
For the VBOX item, please reset the VBOX, and unpair and re-pair the BT side again. Actually, these are the usual action to troubleshoot any wireless sensor connection. In case it still doesn't work, please send detailed information which error messages you get or what you are experiencing. Please send a snapshot of Sensor List too.
For the video: where is it located? In case it is in LapTimer Recordings, please transfer it to Photo app (Move option in Video Details) and check if you can open and play it from here.
Re: XGPS160 issues
Posted: Fri Nov 04, 2016 5:55 pm
by Dan Sweden
Thanks Harry,
I transferred the video as you describe and it worked fine
FWIW: I believe that I've already tried that and that I then got the "Error can not find video selected..." message. Just mentioning this for the record.
Re: XGPS160 issues
Posted: Fri Nov 11, 2016 6:36 am
by drivefast
I just purchased a new XGPS160 this week and have the same exact issue as Veloscaraptor. Same firmware (2.2.1), etc
The work around did not work for me *(unless it was supposed to be a 1Hz work around?)
1)Set Expert Settings ‣ Accessory Tweaks ‣ Use Accessories ‣ NO
2)Ensured XGPS160 connected (solid blue light showing connected and IOS shows connected to Bluetooth)
3)in Sensor Lists -> GPS (only "iPhone GNSS" connected @1Hz)
4)(good news Within Analysis -> Realtime ->GPS screen) - Ensure GPS signal coming from XGPS160 (separate the two and note coordinates) (Confirmed coordinates coming from XGPS160)
5)(bad? news Within Analysis -> Realtime ->GPS screen)- Noticed Device=iPhone Rate=1Hz
Took car out for a test run (worried about 1 Hz)
6)(bad news Exported Data (CSV) only shows 1Hz)
Any ideas to get up and running for a trackday this weekend would be appreciated... but understand troubleshooting takes time:
Are there any known ways to downgrade the XGPS160 firmware that anyone knows about?
Are there any other work arounds you can think of? I'll try anything and am highly technical.
Re: XGPS160 issues
Posted: Fri Nov 11, 2016 8:09 pm
You should see 10 Hz, qualification as iPhone GNSS is as expected.
Please try disconnecting and reconnecting the XGPS.
Re: XGPS160 issues
Posted: Sat Nov 12, 2016 12:59 am
by RaymondAbel
I feel i will keep my 1.41 firmware
Envoyé de mon iPhone en utilisant Tapatalk
