VBO Export to CT; Start/Finish/Splits not loading
Posted: Sun Oct 09, 2016 1:25 pm
I have exported a recent AX session to CT using the VBO format.
Although I have set a start, finish and splits using HLT, when the file loads into CT, the preset points are not used, but the default start point for the loaded track overlay is used.
Can someone advise how to fix this?
I've attached the file.
db
db
