Page 1 of 2
Kiwi 3 with 2003 Toyota MR2
Posted: Sun Sep 18, 2016 12:51 am
by cyaniccypher
When looking at system status it keeps saying for my car: "OBD Data Rate" in red and "The OBD Sensor does not receive data at an expected rate"
I have tried this:
Please add the following string to LapTimer ‣ Administration ‣ Settings ‣ Expert Settings ‣ OBD Tweaks / Exclude PIDs:
Code:
0900092009400902
It did not work.
Anything else that I need to do?
Re: Kiwi 3 with 2003 Toyota MR2
Posted: Sun Sep 18, 2016 9:09 am
Please do not exclude PIDs except when knowing exactly what the problem is. The forum is full of make / model / year specific issues and work arounds and you can just copy them. I assume the Toyota does not have a CAN bus, so the rate will never be very high. The error message however means, there is some communication issue. You may follow the FAQ on "Debugging OBD connections".
Posted: Sun Sep 18, 2016 12:54 pm
by cyaniccypher
Harry wrote:Please do not exclude PIDs except when knowing exactly what the problem is. The forum is full of make / model / year specific issues and work arounds and you can just copy them. I assume the Toyota does not have a CAN bus, so the rate will never be very high. The error message however means, there is some communication issue. You may follow the FAQ on "Debugging OBD connections".
I followed the instructions and send you the logs.
Posted: Mon Sep 19, 2016 10:35 am
The logs show you have 2 ECUs answering most request. Reply are slow, but in the expected range. The replies delivered are often inconsistent, so you will probably see artifacts in data. LapTimer has no filtering capabilities for certain ECUs currently, this would allow removing one of them and both speed up communication and get better data. Maybe in v21...
You may try switching Settings ‣ Expert Settings ‣ OBD Tweaks / Adaptive Timing from Optimized to Enabled - maybe you get better results here.
Posted: Tue Sep 20, 2016 12:31 am
by cyaniccypher
Harry wrote:The logs show you have 2 ECUs answering most request. Reply are slow, but in the expected range. The replies delivered are often inconsistent, so you will probably see artifacts in data. LapTimer has no filtering capabilities for certain ECUs currency, this would allow removing one of them and both speed up communication and get better data. Maybe in v21...
My MR2 has the SMT transmission which has it's own computer that must be the second ECU that is being picked up.
How likely are you to make a fix for this in V21 and how soon would that be?
Next time I go out I will try the adaptive timing setting and let you know how it worked out.
Posted: Tue Sep 20, 2016 9:52 pm
v21 is the Spring 2017 release. This is considered a feature by the way, not fix (as it is working even for this non standard situation).
Posted: Thu Apr 20, 2017 3:48 pm
by cyaniccypher
Harry wrote:v21 is the Spring 2017 release. This is considered a feature by the way, not fix (as it is working even for this non standard situation).
Was this implemented?
Posted: Thu Apr 20, 2017 7:14 pm
I have changed plans for development in the sensors area in general. I plan to provide a scriptable interface for sensors later this year. Instead of building features into LapTimer addressing very special requirements, this will allow users to change integration and data handling on their own. Not committed yet, but excited to work on it!
Posted: Mon Jun 19, 2017 12:36 am
by cyaniccypher
Any update on this? Today I had an event and when I did the overlayed video the engine RPM and the video are clearly out of sync.
Posted: Mon Sep 25, 2017 7:21 pm
by cyaniccypher
Harry wrote:I have changed plans for development in the sensors area in general. I plan to provide a scriptable interface for sensors later this year. Instead of building features into LapTimer addressing very special requirements, this will allow users to change integration and data handling on their own. Not committed yet, but excited to work on it!
Any update?
