Gopoint BT1 firmware/sowtware
stasmagic
Post by stasmagic » Wed May 20, 2015 9:37 pm
Hi!
Can someone check whether its latest version?
Cant get data from car
Re: Gopoint BT1 firmware/sowtware
Post by Harry » Wed May 20, 2015 9:50 pm
From other post here on the forum it seems the 177.0.7 is not the problem (but not sure it is the latest). Please try forcing sequential request in LapTimer / Expert Settings or exclude the BAT request 0720 (exclude PIDs) - which is an expert setting too.
xps911
Post by xps911 » Thu May 21, 2015 12:52 pm
I'm off on track tomo, is there an issue with the gopoint bt1 and the new version ?
Post by Harry » Thu May 21, 2015 2:12 pm
No
stasmagic
Post by stasmagic » Fri May 22, 2015 7:17 am
Enable both BT1 requests and Auto Exclude PIDs, or just try each separate option?
Post by Harry » Fri May 22, 2015 7:30 am
Auto Exclude will probably add more PIDs to excluded than necessary. This option automatically changes the Exclude PIDs entry below. So please turn if off.
stasmagic
Post by stasmagic » Fri May 22, 2015 9:25 am
So turn on seqrequest, off autoexclude and put manualy exclude pid 0720?
Post by Harry » Fri May 22, 2015 9:30 am
Yes
stasmagic
Post by stasmagic » Fri May 22, 2015 9:52 pm
Done. Now this(
Post by Harry » Sat May 23, 2015 5:56 am
There seems to be another problem... Please follow the instructions in "Debugging OBD Connections" here on the forum. It is in the LapTimer / Accessories / OBD section.
