I tried to use my lap timer pro last weekend @ Nurburgring, but i am a little confused with results. Because i dont know was my lap times trigged from Start ( N 50,20,18.7) or from Bridge, because both are triggers ??
So how do i know is my time from Bridge to gate or something else ?
I can send you a data if needed..
Regards,
Kert
[SOLVED] Nurburgring BTG
Re: Nurburgring BTG
Just have a look into your data recordings: Lap List -> select a lap recorded -> press the 'Track' row. Here you see the plot recorded. In case it starts at Bridge, timing was started at bridge too.
Re: Nurburgring BTG
It seems like it has started at Start not Bridge... so how can i get correct time for BTG ?
Re: Nurburgring BTG
Please download the track set named "Nordschleife Bridge to Gantry" (ID: 1000). When asked if conflicting track sets should be purged, press "Purge".
Re: Nurburgring BTG
I have that already, any other ideas ? It never asked about purge..
It has 39 POIS + Triggers
Re: Nurburgring BTG
Harry wrote:Do you see a conflict indicator (red exclamation mark)?
No i do not.. but when i look at the map.. it starts from "boom" gate.
Re: Nurburgring BTG
I send data to your e-mail
Re: Nurburgring BTG
Bad POI deleted i have reload my setup.
Tnx.
Tnx.
