Hello Harry,
is there a possibility to restore laps back to the iPhone by loading the CSV data? Maybe a workaround?
In the worst case I also do have the iExplorer.
The problem was, that I had to reset my iPhone and now all the data are gone, but I still have the CSV.
Georg
Restore laps from CSV?
Re: Restore laps from CSV?
The CSV exports include all the data required to recreate .hlptrl files - which is the only format LapTimer imports. However, a translation is not available from my side and would require some script programming...
Thanks Harry, I think, with some study I should be able to generate them.
Thank you for the Info.
Georg
Georg
Hello Harry,
I created a .hlptr file, which looks the same way as in the other posts. Unfortunately I always get an error while loading.
"Import der Darei ... abgebrochen". Is there a way to debug, to see, what is wrong?
The only difference to the example I see is, that I removed the intemediates and the intermediates tags. Or are the tags necessary?
Georg
Georg
Hello Harry,
thank you very much for your quick help.
All my laps are loaded and look good.
For the others : Please take care that the tags in the hlptrl file need to be case sensitive.
Georg
Georg
I've got the same problem. Can I send you the hlptrz too?
Edit:
I think I know the problem. While beta testing we upgrade to grand prix. On new mobile it installs petrol head only. Is there a solution?
Cheers Marcel
Edit:
Cheers Marcel
Hi, is there process for converting csv to hlptrl files? I've just discovered i've got a data loss and only a csv available.
LapTimer has no CSV import so far. Information is complete, so a technical conversion to .hlptrl will be possible - but it requires scripting.
