OBDeleven OBD Adapter for VAG
Posted: Tue May 14, 2019 12:39 pm
I came across this OBD adapter which has specific support for all of the VAG brands. It basically can do thing that usually require expensive OBD adapters / software like VCDS or VCP to do specific coding on VAG cars. The reason I find it interesting for HLT is that fact it seems to be able to aquire all the VAG specific stuff outside of "normal" OBD2 and HLT might be ablke to make use of it too. For example my Golf 6 GTI has outputs for things like oil temperature, brake pressure etc. but not available via documented OBD2 channels. Here is their web site:
https://www.obdeleven.com/
Basically I'm thinking of "custom VAG OBD PIDs" for HLT.
