What accessories can i pick kart engine speed, water temperature, brake pedal, accelerator pedal position information?
Posted: Thu Jul 06, 2017 2:27 pm
by ayucncncn
:?: :?: :?: :?: :?: :?: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
Re: What accessories can i pick kart engine speed, water temperature, brake pedal, accelerator pedal position informatio
Posted: Wed Dec 06, 2017 7:02 am
by lzzl551
If Harry can support the IOIO board, you can use the Android version of HLT to record these data,But I do not know if Harry has any plans to support IOIO
Posted: Wed Dec 06, 2017 9:58 am
lzzl551 wrote:If Harry can support the IOIO board, you can use the Android version of HLT to record these data,But I do not know if Harry has any plans to support IOIO
See my other post on the IOIO board. Your answer above is probably misleading as an IOIO board is just a hardware / software platform you can build a solution on. It is quite some effort however and requires in depth technical skills. On the LapTimer side, everything is provided to integrate such platforms (see LapTimer Developer Program).
