What accessories can i pick kart engine speed, water temperature, brake pedal, accelerator pedal position information?
ayucncncn
Post by ayucncncn » Thu Jul 06, 2017 2:27 pm
:?: :?: :?: :?: :?: :?: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
lzzl551
Re: What accessories can i pick kart engine speed, water temperature, brake pedal, accelerator pedal position informatio
Post by lzzl551 » Wed Dec 06, 2017 7:02 am
If Harry can support the IOIO board, you can use the Android version of HLT to record these data,But I do not know if Harry has any plans to support IOIO
Cadillac 2016 ATSL 8AT in China 279hp/400nm
Go-Karting Praga Rotax Max Senior 28hp
Laptimer Grand Prix EDITION
iPhone6 64G IOS latest version and Samsung S7 Android7.0
TONWON BTLE OBD2
Gopro Hero4 session
Post by Harry » Wed Dec 06, 2017 9:58 am
lzzl551 wrote:If Harry can support the IOIO board, you can use the Android version of HLT to record these data,But I do not know if Harry has any plans to support IOIO
See my other post on the IOIO board. Your answer above is probably misleading as an IOIO board is just a hardware / software platform you can build a solution on. It is quite some effort however and requires in depth technical skills. On the LapTimer side, everything is provided to integrate such platforms (see LapTimer Developer Program).
