USing a gopro - where to put iphone?
xps911
Re: USing a gopro - where to put iphone?
Post by xps911 » Thu May 22, 2014 9:40 am
ok will try, just want to same on heat etc :)
I will be taking my ipad with me, what app do I need to install to able to control it from my iphone if I want to setup another camera?
Post by Harry » Thu May 22, 2014 9:42 am
Install the free Harry's MultiCam app on the iPad. It is available on the AppStore
xps911
Post by xps911 » Thu May 22, 2014 9:52 am
thanks was searching for that, but realised I had ipad only selected, changed to iphone apps and now appears :)
xps911
Post by xps911 » Thu May 22, 2014 10:00 am
hi, unfort it's not connecting, bluetooth is on both devices. If i go to sensor list multicam is red :(
Post by Harry » Thu May 22, 2014 10:02 am
That ok, connection is done when entering the video view. Check the video docs in addition - it includes a step by step.
xps911
Post by xps911 » Thu May 22, 2014 10:10 am
haha yes that's great :D
xps911
Post by xps911 » Wed May 28, 2014 2:33 pm
worked really well controlling the gopro - now if only the transfer over wifi wouldnt time out! from go pro to iphone :( so annoying, 2gb file
xps911
Post by xps911 » Wed May 28, 2014 3:17 pm
ok i've worked out an easier way to transfer gopro videos (if you have a pc) and without needing to use itunes - works on fully ios version (no need to jailbreak)
1. copy mp4 from gopro to your computer.
2. download i-funbox classic ( http://dl.i-funbox.com/ifunbox_classic.zip ) extract, and run.
3. make sure phone is connected.
4. Browse to user apps - harry laptimer - documents
5. Click copy from PC - browse to the gopro mp4 and will copy across.
6. Go into harrys laptimer, click on relink, and the gopro mp4 will now show with a red ! next to it, click on link and done :)
Post by Harry » Wed May 28, 2014 3:18 pm
Try to use the USB cable, that's usually faster. But I agree, there is room for improvement...
Post by Harry » Wed May 28, 2014 3:21 pm
Yes, that works too and is probably the fastest approach. I do not recommend it usually as one can easily screw up the Documents folder.
