Anneau du Rhin short configuration
robrene
Post by robrene » Thu Oct 04, 2018 12:47 pm
Hey all,
I'm going to a trackday on Anneau du Rhin soon. This time around, the organizers have set up the short layout instead of the full layout.
This will be my first time using Harry's Laptimer. However, I can only find the full layout in the list of tracks. Can someone help me add the short layout for this session? See the image below for reference:
Re: Anneau du Rhin short configuration
Post by Harry » Thu Oct 04, 2018 1:15 pm
Provided the start/finish is the same as for the full layout, you can use this one for now. We will add a short configuration you can move your recordings too later.
robrene
Post by robrene » Thu Oct 04, 2018 1:22 pm
I'm not sure how to check in the app, where the start/finish is for the full track layout. I saw there was a thread in this forum about changing the start/finish to be on the main straight. If this is the case, then the start/finish of the short layout is not in the same location. In fact, the start/finish of the full layout is not even part of the short layout at all.
Post by Harry » Mon Oct 08, 2018 3:15 pm
So it is probably best to use the New Track assistant to create a separate track here. We are off for vacation currently and can have a look into it in one week from now.
Monika
Post by Monika » Wed Oct 24, 2018 2:23 pm
Hi, the short version is now available for download:
In the app: Admin->Add-ons, update list with button top right.
Afterwards search for Rhin and the new configuratio will be listed and can be downloaded.
- Monika
