fay de bretagne track
I'm just looking at the track, and only has a start and finish, I want to add some sectors to it, which I have done (3 around the track), but cant test until I am on track.
I just want some opinions, it is worth adding every corner as a split as corner 1, 2 etc ? leave it how I have done it with 3 splits split around? Is this is what is normally done?
thanks
thanks
Re: fay de bretagne track
For standard GP length track, 2 or 3 splits are the standard. In case you want to run comparisons by corner, I'd recommend using the Data Recordings graphs. Please check the recent posts on a discussion were to place splits best - we had that within the last week.
will it auto do speed on corner etc ?
It will automatically show local minimum and maximum values. To get corner names, they certainly need to be defined in the track set.
and i add them as an information ? if i dont put in corner 1 etc, it will still display corner speeds ?
These are no corner speeds... On a track you typically drive between max and min speeds - straights and corners. LapTimer identifies these max/min values and displays them.
Information POIs are not related directly. Once you approach their position, the overlay will insert them animated.
ah ok many thanks
im sure it will all make sense once i have done a track day with it
