Correct?
Posted: Tue Feb 12, 2019 12:13 pm
by RoNi#'
I bought a Qstarz 10hz bluetooth module and use the "Dyno" app to measure 0-100 oder 100-200kph
The first question is why there are a lot of "how-to" videos for laptimer and nothing for the dyno app?
Second question: is it possible to "correct" the measured times like it is possible with performance box?
or is it maybe possible to export the measured file to computer and correct it with a software on computer?
thank you, I used search but didn't find anything.
thank you, greetings from Austria
Re: Correct?
Posted: Wed Feb 13, 2019 6:21 pm
LapTimer user will not confirm there are lots of video tutorial.
There are never enough.
The reason there is more documentation is that track recording are far more complicated to handle.
On your question:
Not sure what kind of editing you want to apply? For both LapTimer and Dyno we try to make recordings "safe" so the Hall of Fame or other comparison cannot be cheated. But please describe what you want to do and I can probably help.
You can export your data to lots if formats including .CSV, .GPX, .VBO, .KML etc. Select any recording and select the distribute / export button to select the scope and format of export. .VBO can be used for Race Logic tools in case you have them available.
Re: Correct?
Posted: Wed Feb 13, 2019 6:28 pm
To edit altitude, you can export a recording to .HLPTRZ, rename it to .HLPTRL.GZ, unzip it, and edit the resulting .HLPTRL file. .HLPTRL files can be imported into Dyno by sending it by mail as an attachment. Touch the .HLPTRL in Gmail / Apple mail and Dyno will import it.
This however will not adjust your results to reflect the different gravitational work compared to a flat run.
Re: Correct?
Posted: Fri Feb 15, 2019 10:40 am
by RoNi#'
Hello Harry
thank you for your answer.
I wanted like Racelogik that it i do a run with a few meters altitude difference between start and end point you can correct it to "a flat testrun" as you might expect.
I will try to export it to racelogic tools, thank you
Re: Correct?
Posted: Mon Mar 18, 2019 11:28 am
by sikrip
Ι have successfully exported these data as .VBO and used as input to VBOX tools. Worked nice.
