How to import Car definition from HLT to GPS Buddy ?
Posted: Tue Jan 13, 2015 9:38 pm
by KrisS
Hello upgraded to latest version of GPS buddy today and bought satelite and OBD info features. Now for the last one (OBD) to work properly I need the car data defined. I am able to export the car def from HLT rto my mail but how to copy/import it to GPS buddy ? When I press the attachment it allows to choose mail, dropbox and HLT to open it. No GPS Buddy on the list. Any hint / info how to do it ?
regards
K
Re: How to import Car definition from HLT to GPS Buddy ?
Posted: Tue Jan 13, 2015 9:55 pm
GPS Buddy is not registered for any file type, that's the reason it isn't offered to open the .hvehl file. This mean you need to enter the data manually...
Posted: Tue Jan 13, 2015 10:39 pm
by gplracerx
The new lookup feature in GPS Buddy helps a lot with vehicle data.
Posted: Tue Jan 13, 2015 10:52 pm
If Edmunds would add gear ratios, I'd really love them :-)
Posted: Wed Jan 14, 2015 9:32 am
by KrisS
I entered car data manualy. In lookup there is no Focus RS Mk2 btw.
Posted: Wed Jan 14, 2015 9:34 am
Edmunds provided models sold in the US market only. Not sure the MK2 is one of these?
Posted: Wed Jan 14, 2015 10:03 am
by KrisS
Focus RS Mk2 was not fords' "Global model" and was marketed outside US. The scock model data are follwoing:
- Turbocharged / RON 95/98 fuel
-Displacement (cc) 2522
- Max power ISO PS (kW) At engine speed 6500 (rpm) 305 PS (224kW)
- Max torque (ISO Nm) At engine speed 2300 – 4500 (rpm) 440 Nm
- Max engine speed (rpm) 7050 transient (3 seconds) with continuous at 6500
- Engine speed at max speed 6175 (rpm)
- Fuel Tank (litres) 62
TRANSMISSION
Transmission type Manual 6-speed, synchromesh on all ratios including reverse
Gear ratios
6th 0.7
5th 0.868
4th 1.088
3rd 1.433
2nd 2.05
1st 3.385
Reverse 3.231
Final Drive 4.00
- Standard wheel size (in) 19x8.5 Tyres Continental 235/35 R 19
- Overall length (mm) 4402
- Overall width, excl. mirrors (mm) 1842
- Overall height (mm) 1497
- Wheelbase (mm) 2640
- Basic kerb (kg) 1467
- Gross vehicle mass (kg) 1860
- Payload (kg) 543
Mine is a little bit modified I can send the export file from HLT if required
