Page 1 of 6
[HOWTO] Debugging OBD Communication
Posted: Tue Jul 16, 2013 6:02 pm
Before you start going into the detail level logging described below, please use this chart to narrow down what's going wrong.
To debug a car, I need to have a look into the connection sequence and dialog going on between LapTimer and the OBD dongle connected. To log, please use GPS/OBD Buddy, not LapTimer or some other Harry's app. These apps have logging disabled, so the free GPS/OBD Buddy needs to be used.
Here are the steps to collect the OBD communication log and send this trace to me:
  1. Install Harry's GPS/OBD Buddy from AppStore or PlayStore.
  2. Start Harry's GPS/OBD Buddy and find the trace settings: App ‣ Settings ‣ Expert Settings ‣ Tracing (Developer only).
  3. In the Trace Classes page you find so called Trace Classes. Please make sure exactly OBD Troubleshooting is turned on. All other rows should be turned off.
  4. To start logging, return to the Tracing section header and select Logfile from the Type row. Switch to the GPS View. In case you have done everything right, you see a small gray recording symbol in the bottom right. Please note LapTimer is writing the log already - and it is lots of stuff per minute. So immediately ...
  5. ... enter your car, plug in the dongle, and follow the OBD dongle manufacturer's advices to connect the dongle to your iPhone.
  6. Watch the GPS view and wait until you get the OBD gadgets displayed (most probably showing no data and a red dot blinking from time to time). In case you do not get the OBD gadgets inserted, please switch to Sensor List and check the OBD dongle is visible and Connected. Wait a minute (not a lot more) and return to Expert Settings. In case you do not see the OBD dongle in Sensor List, you need to work on your dongle / iPhone connection - LapTimer cannot access the device at all.
  7. Select the row Send Logfile (if available) - and LapTimer will bring up a note including the log file. In case you are not prompted with this prepared email, you need to setup mail operation on your device first...
  8. You are NOT done! Please do not send this file without adding some information I need to debug and understand the context of the mail: a) add the name you used when you pinged me on the Forum or Facebook so I can identify the thread b) add the brand and model of your OBD dongle c) add the brand / model / year of the car we debug.
Now you are done. I will have a look into the log and let you know if there is something you can do to get OBD working with the LapTimer production version available, or if I need to add a bug fix and release another version, or if there is some problem with your dongle / your car I cannot resolve.
Re: [FAQ] Debugging OBD Communication
Posted: Wed Jul 24, 2013 2:28 am
by dcampbell
Thanks Harry I will give this a try. I have a post in the problem cars post with my 2006 BMW 330xi and gopoint BT1. Maybe this will help us. I did notice that when using the gopoint tools it was picking up many more PID info than HLT. So there has to be a secret somewhere to make this work.
Have you got any cooperation from gopoint at all?
Posted: Wed Jul 24, 2013 2:47 am
by dcampbell
File sent. Let me know if I captured a good trace for you. Thank you again for taking the time to debug.
Posted: Fri Aug 23, 2013 7:10 am
by M54ccibo
Hello Harry. Trying to get the PLX Kiwi Wifi working with my 2013 BMW M5. Just sent a trace to you...let me know if it looks good. Specifically, I get CRAZY RPM fluctuations and the shift icon flickers on/off.
Posted: Fri Aug 23, 2013 7:21 am
M54ccibo wrote:Hello Harry. Trying to get the PLX Kiwi Wifi working with my 2013 BMW M5. Just sent a trace to you...let me know if it looks good. Specifically, I get CRAZY RPM fluctuations and the shift icon flickers on/off.
See viewtopic.php?f=20&t=1576
Posted: Wed Mar 19, 2014 10:51 pm
by rollerman
How can i troubleshoot the obd connection with an android device.
I get the message "the obd sensor does not receive data at expected rate" and connects and disconnects a lot from the obd device.
I have a chinese 327 elm obd bluetooth adapter that works just fine with other applications.
Posted: Wed Mar 19, 2014 10:58 pm
In LapTimer for Android the logging capabilities are enabled. So please just follow the description above and use your LapTimer Rookie edition instead of GPS Buddy.
Re: [HOWTO] Debugging OBD Communication
Posted: Thu Feb 12, 2015 10:41 pm
by froggy47
Got OBD2 MX BT today with high hopes. It connected quite easily to the companies diagnostic software (an app on my android phone). Not so much with HLT. It seems maybe it "paired" as I can see it on the sensor list. But connect, no.
Do I need to uncheck all those expert settings that I checked for the generic obd2?
I only bought this for HLT as the generic works fine with Torque.
Please help.
Thanks.
Also how do I delete sensors that are no longer in use, can't seem to get rid of them. Press/touch/long touch/drag/etc.
Posted: Thu Feb 12, 2015 11:45 pm
On basic connection level, make sure you have only one app at a time accessing the dongle. If for example the OBDLink app is active in background, it may block the connection for LapTimer. Once LapTimer is the only app accessing the dongle, check it appears in Sensor List with a green / connected status. In case you see no update rate (or 0 Hz), there is a problem on protocol level. In this case, you may follow the route in the first post of this thread. In case you want me to check you settings first, please create snapshots showing all OBD Tweaks from Expert Settings and post it here.
Posted: Thu Feb 12, 2015 11:49 pm
by froggy47
Harry wrote:On basic connection level, make sure you have only one app at a time accessing the dongle. If for example the OBDLink app is active in background, it may block the connection for LapTimer. Once LapTimer is the only app accessing the dongle, check it appears in Sensor List with a green / connected status. In case you see no update rate (or 0 Hz), there is a problem on protocol level. In this case, you may follow the route in the first post of this thread. In case you want me to check you settings first, please create snapshots showing all OBD Tweaks from Expert Settings and post it here.
Yes I turned off OBDLink first.
Will try to figure out how to post expert settings.
Really the only 3 checked per your previous attempt to get generic obd2 working, are:
auto exclude pids
ignore no data/nak replies
force insecure bt connection
nothing else touched
How do I delete sensors no longer in use?
Do I want to pair the obd2 with the android PHONE AND HLT or just HLT?
Tried some more without changing anything, it's connecting for about 1 second and dropping, this with key on engine off or engine running.
At this point not much better than the generic except cost more.
The generic (Blue VGate) did actually work decently (not perfectly) for a few laps then I put it away & next time I went to use it was the "not connecting". Of course this is very frustrating.
