Cases with tripod mounts.
Discussions related to iPhone and camera mounts
rscliofan
Re: Cases with tripod mounts.
Post by rscliofan » Tue Apr 16, 2013 4:55 pm
I couldn't see one with a flat adhesive mount attachment?
UK track days now more often than not require an adhesive mount.
tulloch
Post by tulloch » Tue Apr 16, 2013 7:10 pm
Sorry, didn't realise that's what they are looking for. Ram do mountings that can bolt to headrest rails and side windows. You can marry them with an arm and a GoPro mount. I use the headrest rail U-bolt mount for an in car mount. These would be acceptable I think.
rscliofan
Post by rscliofan » Wed Apr 17, 2013 8:32 am
Yeah but I've got recaros so I've no head rest as such as its all in one seat.
Thanks anyway, the search goes on.
hms
Post by hms » Sat Apr 20, 2013 4:48 pm
Here is the Mannfrotto Klyp case
The two little bits are the adaptors which clip onto any of the three corners, one is the tripod mount, the other a flash adaptor.
Other Mannfrotto bits to mount to rollbar, superclamp is the main clamping portion, other bits may be used as necessary as the Mannfrotto system is very flexible.
Phone and case fitted to flash bar
Using both adaptors so that case has two contct points on flash bar to reduce movement.
And the whole lot fitted to roll bar
Mount seemed nice and solid on track, iphone could be charged whilst in case. Very pleased for it all to work.
Will post video up in due course.
H
xps911
Post by xps911 » Sat Apr 20, 2013 6:17 pm
That looks a nice setup. Do you have a wide lense ?
hms
Post by hms » Mon Apr 22, 2013 10:06 am
No standard iphone. I am loathe to spend the extra money on a lens that will not fit the iphone 5, when I upgrade next.
Vidoe using the system can be found in this thread.
http://www.wheels-inmotion.co.uk/forum/ ... opic=11468
No video from multicam, trying to work out how to mount a second phone.
h
