OBD Tonwon 4.0
AdrianoJP
OBD Tonwon 4.0
Post by AdrianoJP » Fri May 25, 2018 8:11 pm
Hello Harry,
I have purchased the Tonwon OBD dongle, and successfully paired it with LapTimer. The refresh rate appears to be 1-2Hz only (tested with key-on, engine-off): do I have to enable BT1 or other settings in order to enable full data transmission speed?
Secondly, Laptimer tells me that I need to insert correct rpm and transmission ratios in order to display correct speed/gears?!? Is this true?
I am driving a Mk7 Golf R.
Thankyou in advance!
Re: OBD Tonwon 4.0
Post by Harry » Sat May 26, 2018 8:49 am
Assuming your Golf has a CAN bus, the update rate is too low. For non CAN cars, this is the expected rate. Test with running engine please. There is no further configuration required. As the upcoming LapTimer v22 will come with a completely revised OBD integration, I do not want to go into full trouble shooting currently. Please search the forum for options to make OBD update rates more reliable. In case you can't wait, please join the early access / beta program.
And yes, LapTimer speaks the truth on gear calculation. Please search the FAQs on how to configure your gear ratios.
Mateusz
Re: OBD Tonwon 4.0
Post by Mateusz » Mon Jun 04, 2018 1:26 pm
I assume Tonwon OBD has the same internals as iCar3 BTLE, which I have. Low update rates are typical for engine-off situation. I get 6-8Hz with the right configuration, which, I understand, is as good as it gets with BTLE.
