[OP3+OBDLink MX+XGPS160] Choppy OBD data when XGPS160 in use
schluerfi1978
Re: [OP3+OBDLink MX+XGPS160] Choppy OBD data when XGPS160 in use
Post by schluerfi1978 »
Hi all,
I just stumbled across this topic, and I think you are describing the same issue that I was posting here: viewtopic.php?f=8&t=5489&p=27737&hilit=steps#p27737
Did you get the issue fixed also on the Version 23 or 24 Beta with the aforementioned lowering of sensor delay times? I'd love to run out to the garage and give your solution a try right now, but my 2008 BMW E86 is away for major overhaul for a few weeks :roll:
Also, you are mentioning the "OBD Extrapolation" setting. This entry in the settings seems to be gone since V23?!?
My setup: Android 9 on Samsung S8, HLT Grand Prix, iBlue 747a+ GPS-Logger at 5 Hz, TonWon Bluetooth OBD Dongle (delivering 1 Hz on the E86-BMW)
With best regards,
Michael
