So you mean:
1. Pull out OBD dongle from car
2. Start HLT - expert settings - set PID 3 adaptive.
3. Start logging only for OBD Sensors
4. Start engine, put in dongle and wait for connection
5. After connection, In sensors list check available PIDs (and make screenshots)
6. Don't rev engine? Keep it on idle? Don't push throttle pedal
7. How long i must wait before finish logging?
update rates on bluetooth android/iphone compatible
- PitrsRS
Re: update rates on bluetooth android/iphone compatible
2016 SEAT Leon CUPRA 290 ST
Everything correct except the rev'ing. Please test some throttle positions so the range of values delivered is getting bigger than the range we have seen before.
Please log something between 30 and 60 seconds once the connection has been established.
- PitrsRS
Ok i will try it
- PitrsRS
Email on the way
