roqyBT4 and Bluetooth OBDs!
Re: roqyBT4 and Bluetooth OBDs!
If u are able to support two BT device such as gps and OBD info, will so much data make the connection unstable?
@Doborder
Yes, I'm working on a version to get multiple connection at the same time (GPS+HRM, GPS+OBD mainly).
I need to test it to get the Apple bluetooth stack stability. With 1Hz GPS and 3Hz OBD, I think there is no issue. With 10Hz GPS and 10Hz OBD, I don't know, it needs to be tested!!!!
Roqy
Roqy
Roqy,
I have a 10hz gps qstarz 818 as well as OBDKey which is running approx 3hz on my car. I would be happy to beta test it for you. contact me at mchangdo@yahoo.com
Thanks for your good work!
Hi roqy and Harry,
I just got the Lap Timer Pro and roqyBT working. I have the following BT OBD2 dongle:
This dongle works with my laptop with a continuous connection that avg 10hz.
However, it won't consistently connect or stay connected to Lap Timer Pro. Using the Timer or Timer/Video, the OBD data would come up intermitently and is not usable...in fact connection is dropepd 80% of the time during logging. Again, I have tested the dongle with a laptop, and it works: connects, stays conencted, and sends data...with the iPhone 4 and Lap Timer Pro, it won't even stay connected.
Please help.
Other than this, the program is working great. I look forward to being able to tether a 10Hz BT GPS receiver and 10Hz OBD2 BT dongle to Lap Tiemr Pro!
Please help.
Just to check if it is the same pattern like the one with WLAN dongles, or a different one: it connects to the OBD, shows some OBD data (best seen using the Speedo view), works for approximately 60s, drops connection for 5 seconds or so, reconnects again, etc? Or a different pattern?
Hi Harry.Harry wrote:Hi,
I can't say because I haven't seen the Wi-Lan issue, tho I've read briefly about it and briefly thought they were related. Anyway, for me, it'd work for less than 60sec...then would be disconnected for anywhere from 1 - 2 min then connect for maybe 10sec. The highest rate it connected was also 3.7Hz.
Thanks for the prompt reply!
EDIT: I have just updated with the latest version. I'll try again today in a few hrs and report back.
Updated app. No change. Same behavior.
Fobio wrote:Hi roqy and Harry,
Please help.
Hello.
I would like know if this obd II dongle is compatible with laptimer pro withouth need of doing jailbreak to the iphone.
Thanks.
Bluetooth dongles generally requires a jailbreak to work. To my knowledge there is no Apple certified BT dongle available at all. Please check http://www.gps-laptimer.de/Compatibility.html for a list off supported devices.
And it's possible integrate roqyBT4 on laptimer?
