I've got a Garmin GPS in my Ariel Atom, with the ecoRoute HD transmitter.
http://gbr.garmin.com/ecoroute-hd/
It's basically a dongle that connects to the ODB-II port and transmits (via Bluetooth) air temperature, coolant temperature, throttle position, engine load, intake manifold pressure, battery and charging system information, mass airflow rate, timing advance and emissions info to the Garmin GPS. It would be great if was also compatible with LapTimer - some of that info would be great on the video overlays. The ecoRoute HD transmitter is only $100 retail.
Obviously, since BT devices are paired, it couldn't transmit to Garmin and iPhone simultaneously. Although, it would be awesome to somehow connect all three devices (Garmin Nuvi + ecoRoute OBD-II transmitter + iPhone with LapTimer) and have them work together!
Support for Garmin ecoRoute HD transmitter?
Re: Support for Garmin ecoRoute HD transmitter?
Nice solution, but - as most BT devices - cannot be connected to the iPhone.
