No Video
All Optrix VideoPro related discussions
Steve croxton
No Video
Post by Steve croxton » Sun Oct 28, 2012 11:42 pm
If I record a long video, I run out of memory and the video is lost. I race in two hour long races and have about 5.3 g of memory. I figured when the phone runs out of memory, it would just stop recording, but I loose everything except the lap timer. any suggestions?
Steve
Re: No Video
Post by Harry » Mon Oct 29, 2012 7:03 am
That will be fixed with the upcoming version 16.7 It comes with a reworked recording engine.
Steve croxton
Re: No Video
Post by Steve croxton » Mon Oct 29, 2012 8:39 pm
When will the new version be released? This app is useless to me until that happens. Next race is 2 weeks away, any suggestions? If I use the video (not the app) on my phone will it just stop recording when the memory is full?
Re: No Video
Post by Harry » Mon Oct 29, 2012 8:46 pm
Next version will stop video recording once a certain memory limit is reached. I cannot give an exact date for the release as I a) want to add some more improvements b) need to go through a full testing cycle and c) depend on Apple's approval process. I try my best but 2 weeks is pretty tight.
You may go for the current LapTimer Pro version (16.6.x) as it has all of that included already.
Steve croxton
Re: No Video
Post by Steve croxton » Tue Nov 27, 2012 11:44 pm
I've recorded several videos then deleted but my phone says videopro is using 4 gb of storage. Any thoughts ?
Re: No Video
Post by Harry » Tue Nov 27, 2012 11:46 pm
Open the "Videos" tab and check if you find videos with a red exclamation mark. These videos are not used / are not associated with any lap and can be deleted. Either delete them individually, or use the "Housekeeping" button.
Steve croxton
Re: No Video
Post by Steve croxton » Thu Nov 29, 2012 1:47 am
No videos there, plus after I record the lap timer finished message will not go away. I would like to delete the app and reinstall it. Is that possible?
Re: No Video
Post by Harry » Thu Nov 29, 2012 7:01 am
Yes, certainly. Goto springboard, and long-press the LapTimer icon. Once it shakes, it will have a black cross attached in the top left. Press it to delete the app. To reinstall, just go through the AppStore purchase again. You will not be charged twice.
Doosman
Re: No Video
Post by Doosman » Mon Jun 03, 2013 12:54 pm
Glad I stumbled upon this forum. I seem to have the same problem with the Optrix Video Pro data. If I go into the app, my recording list is empty. However, when I go into settings on the iPhone, I can see under Usage, there there is 15.5 GB of data sitting there. I have been advised to delete the app and reinstall BUT I do not want to loose the data if at all possible.
Is there any way i can extract it from the phone?
Clint
Re: No Video
Post by Harry » Mon Jun 03, 2013 5:48 pm
Please check this link (viewtopic.php?f=8&t=679) for a tool named iExplorer - which will allow you to copy any video from VideoPro's Documents folder to your PC. Once you have saved your data, delete and reinstall the app, that's best.
