GPS + data over single bluetooth
A number of ways you can support LapTimer development
MiataCory
Post by MiataCory » Sun Nov 10, 2019 4:45 pm
Hi, I'm trying to DIY some additional sensors. I've got a 10hz GPS going over bluetooth just fine (Navspark mini + ESP32).
I've also got an arduino reading Throttle Position and Brake application, and would like to send this *with* the GPS data. Is there a way to do this over a single bluetooth stream, or will I need a 2nd bluetooth device/connection?
Re: GPS + data over single bluetooth
Post by Harry » Tue Nov 12, 2019 12:07 pm
This will require a custom integration using our Developer Program (viewtopic.php?f=11&t=4572). One solution I can think of is inserting special NMEA sentences with the TPS/brake information on the Arduino side. In the HarrysLua script (see Developer Program) on the LapTimer side, you'd filter these sentences out and create engine fixes / data sets from them. The rest (GPS) can be forwarded to the built in NMEA parser LapTimer has.
As a work of caution: this will require scripting skills and has not been done before. But it should work. ;-)
MiataCory
Post by MiataCory » Tue Nov 19, 2019 11:21 pm
Thanks for the direction! Scripting is no problem, I just didn't know where to look!
I'll spend a few days going through the documentation and see what I can come up with.
I've already built a DIY logger with a raspberry pi using python and all these sensors, but I lacked the ability to analyze the data without really spending a ton of time creating another program. I tried converting my captured data into a .vbo file but couldn't get it all working in any of the analysis programs.
At which point I decided that buying your app was a much better/cleaner/easier solution!
I'll be sure to update this thread as I go along, and put anything I make up on git for others.
