Features planned for LapTimer v16
Dear friends of LapTimer,
The list of features that will be available in v16 is nearly finished - and it is huge. I will start beta testing shortly and plan to release v16 this summer. Usually major releases appear in spring and autumn, so this is the "Summer Surprise Release" :-)
Code: Select all
UPDATE VERSION 16.0
- Major update with changes almost everywhere
- User Interface improvements
	LapTimer can be operated in landscape now (namely added landscape Timer, GPS, and other views)
	Please note: rotation is blocked while driving
	Generalized recalibration detection when iPhone is rotated
	Tab bar automatically hides if not used, several views use additional space
	Allow manual operation for tab bar hiding
	Added new Video List view to allow easy video maintenance
	Added number of laps by track
	Improved hover and activity views
	'Last Max' Acceleration gadget added, 'Lap #' gadget added
	New, fancy, alert views
	Alerts auto hide after some time in case they are information only
- Video Improvements
	Added a large button to stop video recording
	Moved video links to LapTimer's database
	Much improved video link handling including 'revert to orignal video'
	Full reference handling for videos (last link removed will allow deletion)
- Additional sensor support
	Improved sensor connect / disconnect handling
	Accelerator update rate raised to 30 Hz (by far more responsive), added expert setting to further tweak it
	Made OBD reply recognition more reliable
	Support for multiple replies from car's ECUs
	Added alternative throttle PID support for OBD
	Added gopoint BT1 and gopoint GL1 support
	Enhanced Lap Detail view by sensor information
- Export Format Improvements
	Reworked VBO export (includes better trigger compatibility, interpolates fixes to 10 Hz)
	Enhanced KML export to support lineal acceleration
	Unified standard CSV and overlaying software CSV formats, added both metric and imperial columns
	Additional export scope: export by session
	Trackday and session exports work relative to lap selected
	Added video links to .hlptrl export (allows full restore)
- More vehicle and track types
	Added bicycle support (on top of cars, karts, motorbikes)
	Track set type added, search in Tracks allows selection by track set type
- System improvements
	Significant performance improvement of Lap List
	Redesigned start-up sequence, better messages on migration / data checks
	Several memory optimization
- Online Racing
	After the fact submission of lap times to Hall of Fame
- More Settings
	Reworked Settings grouping, moved some Expert Settings to Settings
	Added setting to trigger at low speeds
- Others
	Startup sound (turn off sounds to get rid of it)
	Added a 'Set Reference' button for continuity racing
	Dozens of smaller fixes and UI improvments
Please do not ask for availability schedule, it gets available when it is finished - this summer ;-)
Hope you enjoy it!
sylvain007
Re: Features planned for LapTimer v16
Post by sylvain007 »
Does it mean that I will be able to have the details of my water temp (Kiwi Wifi) tracked together with the lap record?
sylvain007 wrote:Does it mean that I will be able to have the details of my water temp (Kiwi Wifi) tracked together with the lap record?
No :-) This simply means that Lap Details give you information which sensor data is available and at what update rate it has been recorded.
cannon1000
Post by cannon1000 »
Just got the GoPoint OBDii. What a great find! The interface is great, the price can not be beat. Can't wait to use it w/HLTP!
Dubbedown
Post by Dubbedown »
Bump, any update on tentative release date? looking to pull the trigger on GoPoint but would like to wait till v16 is released =)
Dubbedown
Post by Dubbedown »
On a related note, sucks that I bought my emprum not too long ago only to find out iPhone 5 is doing away with the 30-pin adapter and going smaller, 19 iirc.
Yes, agreed. Hardware evolution and related compatibility is always an issue. That's the nice thing about software, it can be made compatible in the next release again. On the other hand - what Apple demands from us users on the hardware side - they give back on the software side. Compare iOS development and compatibility to old iPhone with the Android situation. That's way better for Apple users. Probably a good topic for a long (but separate) thread :-)
2thomas
Post by 2thomas »
would it be a good idea to display on the laping page the track you selected to drive? i missed yesterday a whole session cause i still was with vln instead btg on the nuerburgring.
thank you
thomas
