Bugfix release LapTimer v15.0.2 available
Posted: Wed Apr 25, 2012 10:35 am
[ORIGINAL TITLE: Problems with LapTimer v15.0 / v15.0.1]
Hi folks,
This is to inform you that the above versions have a bug impacting many users - and creating several follow on problems in addition.
Problem is that LapTimer crashes at the end of the second video recorded lap if the initial lap has been triggered by a stop/go (instead of a go) trigger. Oddly, I did not have this case in my - or my beta tester's - test cases... And so we missed the bug... As this operation is probably a very frequently used one, this creates quite some issues currently. I have a fixed version available now and will submit it to Apple asap (after having run some additional tests).
The only way to work around this currently, is not to video record tracks set up using stop / go (instead of a separate go and stop) trigger. Operation without video, and video recording using go and stop should work however.
Once I have submitted the fixed version 15.0.2, I will request a fast path from Apple, hope they accept.
Re: Problems with LapTimer v15.0 / v15.0.1
Posted: Wed Apr 25, 2012 2:27 pm
Version 15.0.2 for LapTimer, LapTimer Pro, and LapTimer Trainer have been uploaded to Apple for approval.
In addition I have requested a fast path for the approval process.
I will keep you posted here.
The full list of changes is available here:
* Added autorecovery function to repair database inconsistency detected
* Added some defensive code to video checkpointing //IPHONEVERSION
* Added some defensive code to Dm32 node creation //IPHONEVERSION
* Fixed a problem in autorecovery function / database check
* Added error codes for non-recoverable database problem and added them to
* alerts shown to users
* Removed the lead titles option again //IPHONEVERSION
* Added recovery strategy for misplaced GPS fixes
* Fixed issue with track sets working with stop/go triggers only, fixed crashes
* that occured at the end of the second lap while video recording //IPHONEVERSION
Posted: Thu Apr 26, 2012 4:46 pm
Hi again,
My friends at Apple did a great job prioritizing app review for 15.0.2:
just got information LapTimer Pro v15.0.2 is processed to AppStore already
So please check, all three apps should be available from there within the next hours.
Keep your fingers cross and let me know if this version fixes the issues introduced in v15.0.1
