Share your video !
Introductions and general exchange between LapTimer users; use this forum in case you want to offer LapTimer related accessories too
GlnkNL
Re: Share your video !
Post by GlnkNL » Thu Sep 18, 2014 3:29 pm
bulls23 wrote:
GlnkNL wrote:How can I split the Nurburgring GP lapcount with the Nordschleife BTG lap count? The Nordschleife lap shows lap 2/8 but the other 6 laps are my GP track laps.
Select each of the GP laps and simply edit the track they are linked to.
I tried but that didnt work. It's like theyre linked by date/time not by track
bulls23
Post by bulls23 » Thu Sep 18, 2014 3:33 pm
Maybe this should have an own thread...
So you're talking about the daily "lap counter" and not about those laps being linked to the wrong track set. If I remember correctly, that can't be changed afterwards.
GlnkNL
Post by GlnkNL » Thu Sep 18, 2014 3:41 pm
Yep that's what I mean. 2/8 makes it look like I did 8 laps. I'm going to put a mask over it to cut that part out in my video editor. Also increased the speed of the overlay data by 100,03% to 'fix' the out of sync issue thats caused by the camera roll
bulls23
Post by bulls23 » Thu Sep 18, 2014 3:46 pm
GlnkNL wrote:Yep that's what I mean. 2/8 makes it look like I did 8 laps. I'm going to put a mask over it to cut that part out in my video editor. Also increased the speed of the overlay data by 100,03% to 'fix' the out of sync issue thats caused by the camera roll
Just checked my videos from last weekend and I can't confirm the change of fps. Both videos dragged directly from the HLT documents folder with iFunbox and overlayed ones from the camera roll are 29,97fps @1080p. The time it takes to move the video to the camera roll also suggests it not a fps conversion.
GlnkNL
Post by GlnkNL » Thu Sep 18, 2014 3:54 pm
Harry's Laptimer > Camera roll > Autosync with Dropbox
Input: 30fps 1080p empty blue screen (downloaded from my Dropbox onto camera roll then loaded into HL)
Output: 29.97fps 1080p blue screen with overlay
And then when I check the overlay video seconds vs my final cut pro actual seconds it goes out of sync
I tried changing my iPhone region format but that didn't help
bulls23
Post by bulls23 » Thu Sep 18, 2014 4:02 pm
GlnkNL wrote:Harry's Laptimer > Camera roll > Autosync with Dropbox
So the blue screen video in the Dropbox was always 30fps? If so...why don't you simply upload a 29.97fps blue screen video?
GlnkNL
Post by GlnkNL » Thu Sep 18, 2014 4:17 pm
Hm I gave you the wrong info. The empty blue screen video from my dropbox is 29.97 fps and so are my GoPro video's but when I import the blue screen with overlay in final cut pro it is 30 fps whereas my GoPro video is still 29.97 fps.
It's weird though because the empty blue screen registers as 29.97 fps in FCP
The same blue screen but with the overlay registers at 30 fps in FCP
But VLC media player says 29.97 fps for both. Im confused :P
GlnkNL
Post by GlnkNL » Thu Sep 18, 2014 6:37 pm
Now with synced overlay:
[youtube]http://www.youtube.com/watch?v=JXhdTUaOLVI[/youtube]
Post by Harry » Thu Sep 18, 2014 10:48 pm
The helmet mount makes is pretty dynamic - like it.
xps911
Post by xps911 » Fri Sep 19, 2014 10:34 am
GlnkNL wrote:Now with synced overlay:
do you have a pic of the camera mounted? quite like that view
