Motorola moto g
Introductions and general exchange between LapTimer users; use this forum in case you want to offer LapTimer related accessories too
acrobat
Motorola moto g
Post by acrobat »
I am getting a motorola moto g phone for the purpose of recording video and doing overlays for track day. will this phone have enough processing power to do so? i may also use a bluetooth adaptor to add OBD 2 info as well
Regards
Re: Motorola moto g
The Moto G is slightly below the processing power recommended, but may well work. OBD2 recording in realtime is sensible, too low processing power or number of processor cores can lead to lags in processing - which can become visible in overlays. I'd suggest to try it out, but not add too many options from the beginning.
acrobat
Re: Motorola moto g
Post by acrobat »
OK thanks
I am really looking for the cheapest option possible. I have a phone for daily use which is unfortunately not supported so what I get will be only for use with your app
acrobat
Re: Motorola moto g
Post by acrobat »
One other question can your app use quad core processors or does it only use 2?
Re: Motorola moto g
Android apps are pretty multi-threaded by nature. In addition, LapTimer uses additional cores for sensor handling, which greatly improves accuracy, for sensors without timing information (like OBD) in particular. So yes, 4 cores are good for LapTimer.
acrobat
Re: Motorola moto g
Post by acrobat »
OK good I'll try the moto g and let you know how it works. It supposedly has a 4 core processor. I saw the recommendation on the website and the test was for 2 cores only so I hope if it uses 4 cores it will be fine
