Page 2 of 3
Re: Dual XGPS160 10Hz support
Posted: Sun Nov 24, 2013 5:09 pm
by 38F/62R
Harry wrote:At least I did not run into it any more lately...
I still have to go into my iPhone settings every time I start HLT and reconnect the XGPS160. I don't recall needing to do that with the XGPS150. If I remember correctly, every time I turned on HLT and was in range it automatically connected. The 160 doesn't do that though. Any suggestions? Thanks
Posted: Sun Nov 24, 2013 5:11 pm
38F/62R wrote:Harry wrote:At least I did not run into it any more lately...
In case you need to pair the devices each time, please contact Dual on this.
Posted: Mon Nov 25, 2013 8:37 pm
by gplracerx
It wasn't pairing that was the problem, it was connecting when it was already paired. When you turned on the XGPS160, the bluetooth led would be steady but the bluetooth page in iOS settings would show not connected until you tapped it to re-establish connection. I need to check this, but I suspect the firmware update, which couldn't be applied until the iPhone app finally came out, fixed this problem. But yes, it needs(ed) to be fixed by Dual, not you.
Posted: Mon Nov 25, 2013 10:06 pm
Yes, that's the same area...
Posted: Mon Feb 03, 2014 5:00 am
by markchristenson
It appears that the XGPS160 is significantly larger than the 150--true? I am a motorcycle guy and the 150 fits nicely into the tail section of my bikes, but I don't think the 160 would
Posted: Mon Feb 03, 2014 8:53 am
XGPS160: 2.7" (70mm) wide x 2.2" (55mm) tall x 0.8" (22mm) thick
XGPS150: 2.25" (57 mm) square, 0.75" (19 mm) deep
Posted: Mon Feb 03, 2014 4:44 pm
by markchristenson
Harry wrote:XGPS160: 2.7" (70mm) wide x 2.2" (55mm) tall x 0.8" (22mm) thick
I'm glad I asked--from the Amazon product page it has the wrong information:
"Product Dimensions 5.4 x 5.1 x 2.7 inches"
I may have to give this one a shot!
Posted: Mon Feb 03, 2014 4:51 pm
I took it from Dual's web site. The XGPS160 is a little bigger than the XGPS150 - but not a lot.
Posted: Wed Aug 20, 2014 3:29 pm
by devenh
Does the XGPS160 have the slot on the back for a strap like the XGPS150a does? I ask because I use the slot on the 150a to attach some suction cups which allows me to mount the unit on my windshield.
If it doesn't have the slot, how do you mount it in your car?
Deven
Posted: Wed Aug 20, 2014 3:42 pm
devenh wrote:Does the XGPS160 have the slot on the back for a strap like the XGPS150a does? I ask because I use the slot on the 150a to attach some suction cups which allows me to mount the unit on my windshield.
Deven
No strap slot like the XGPS150. I personally use the rubber plate. As long as the dashboard is clean and the rubber is washed from time to time, it is pretty sticky. In case it doesn't stay where it should, use an adhesive strip (for the rubber plate, so you can remove the mouse)?
