Can you please add the value max RPM in the engine settings part of the vehicle settings, and take this value to calculate the diagram (instead of the RMP at max HP)? Thanks.
Oliver
Re: max RPM in the engine settings
Yes, that's on my list already. Most of the time it is a good approximation.
Please also change the input from the spin dials to a numerical input. Spinning up to 9,000 RPMs is painful, especially when you accidentally hit cancel!
Rob Rockefeller
2003 Honda S2000
SCCA Solo - STR
2003 Honda S2000
SCCA Solo - STR
Yes, that's on the list like a separate max RPM and a threshold for the gear shift indicator.
