Set temperature / overheat warnings
Posted: Wed Dec 28, 2016 12:11 pm
Hi, Would it be possible to add this feature. I would like to be able to set alarm threshold temperatures for OBD data (inlet temp and coolant temp). If the user set temperatures were exceeded the phone would alert "COOLANT TEMP TOO HIGH" or "INTAKE TEMPERATURE TOO HIGH".
Also is it possible to enable customisation of the gauges screen so bigger gauges could be shown? Unfortunately the current gauges are a bit too small to read whilst driving on track. Also to me (and I think others) RPM / BHP isn't really relevant for monitoring I would like to see engine critical parameters next to each other coolant, intake, exhaust temperatures. Is this possible? It would be great to log peak temperatures for these items too, you could click the gauge and it would display last peak temperature with option to reset.
Another small issue is I would like to display temperatures in celcius whilst speed remains in MPH. Would this be possible? Unfortunately if you switch to metric then speed changes to KPH. Change to imperial and temperature changes to farenheit. You can currently cycle through HP / PS / KW by clicking on the spanner symbol in gauge view, I'd like to be able to do the same thing on temperature between C and F.
Thank you!
Thank you!
